Increase Boost
Increase Boost
I finally got the dual exhaust mounted up to the headers and now I understand, with that much back pressure loss, I'm losing boost. My question is, without having a boost guage yet, how much boost am I possibly now losing? The Whipple was rated at 8 psi out of the box, if say I lost 2-3psi with the exhuast and I install a smaller pulley to get back to 8 psi, will I see a hp gain over what I had before the headers & exhuast?
Originally Posted by 98Navi
Boost = Increased output
Lower boost due to lesser restriction = Same increased output with less increase
Reduction of pulley to retain 8 pounds of boost after mods = increased output from mods + increased output from smaller pulley and, ah F it
It'll go faster, yes.
Boost is simply a measure of restriction.
Reduce the restriction (intake, headwork, cam(s), exhaust) and your boost will drop. But that doesnt mean your output will, it just means that the SC will have to be worked harder to SEE the same amount of boost.
To answer your question, anytime you decrease the restriction in a boosted motor, you INCREASE the efficiency. This is a good thing. The motor isnt being worked as hard, and that will be very niticeable if you keep an eye on the EGTs. They should lower a good deal
Your fuel pump and injector "boost" ratings are irrelevant. I really hate it when they apply ratings like this.
What you really need is a CFM rating. Seeing that a motor is just a very large air pump, and you need a set amount of fuel for every bit of air it injests.
Do you have any tuning device? Or even a wideband?
With my new exhaust, the motor is now more efficient, but if I increase boost, I'm back to where I started with the stock exhaust in relation to the efficiency, but I will generate more HP? Of course. I understand that if I do this, it would require a good custom tune. Other than the obvious of getting a bad tune and causing a break, is there a better way to increase HP this easily and cost efficient?
Do keep in mind the old saying.
Fast, Cheap, Reliable. Pick TWO.
Slapping a smaller pulley onto the blower will increase its output. But it will also increase it's air output temps (whish also lowers efficiency). And we all know that heat is the devil in any motor.... especially boosted ones.
Also, once you get to the point of increasing boost to bring your respective boost readings back, you are to the point of finding the weakest link. Normally that weakest link is non-forged pistons.
You should be able to safely reduce the size of your pulley to achieve pre exhaust psi with minimal change to the programming. (*assuming its been tuned)
928 Motorsports sells pullies on ebay, and they provide you with a formula to calulate supercharger RPM and safe ranges. Check them out
Thanks for the info, but I have been talking to Doug @ BamaChips and Whipple and both agree that a 3" pulley would be safe for my application. I pulled the trigger and ordered it. Of course, I understand the tune is the key to this mod. Doug told me the 3V are good for 500hp at the wheels with the stock internals, but feels more comfortable staying at 450.
