a couple of questions before my harley s/c swap
#31
#32
#33
#35
oh crap those are bigger issues. I wish I was more knowledgable on this and could help. I know somebody did this and modified their fuel system to a return type on the ford truck enthusiasts site but I don't remember who it was...jarepackard maybe
Maybe some of these can help...
http://www.ford-trucks.com/forums/35...dition-eb.html
http://www.ford-trucks.com/forums/21...ercharger.html
http://www.ford-trucks.com/forums/55...ing-model.html
http://www.nhtoc.com/vbforum/showthread.php?t=16189
https://www.f150online.com/forums/sh...d.php?t=260511
#37
OK, some of these issues are coming back to me now. I had one customer who made the swap on an '03 (I think) and he re-used the original engine harness from the truck. I think he had to extend a couple of sensor leads but in the end it all connected up and worked. Any of the sensors or controls on the rail alongside the blower that do not have a plug in the OE harness are for the Boost Dump. These won't connect but it doesn't matter since your PCM doesn't know what to do with them anyway.
The returnless fuel system is another issue. Unfortunately he didn't share his resolution of that with me. However, anybody who has done an '04 or later F-150 will have the solution for you.
Sounds like you may have to make your own H/E Brackets but remember, anything unused is returnable (no restock charge) assuming of course it is still in new condition.
I'll help you all I can here but we may need some help from other board members. There weren't too many trucks like yours with the 2V engine but with all the 3V ancilliaries.
#38
Originally Posted by 03expyeb
todays update. the crank pulley bolts that come from mike will not work on the expedition block. we had to go to the hw store and get 3/8 instead of the metric ones that came with the pulley. no big deal...just for reference.
#39
mike, thanks for the info. i got a response from someone who did the swap on an 04 2v, which is the same as mine. he said what you said about the harness. he also told me how to go about the fuel system.
as far as the bolts, i went up and watched him try to install them. they wouldn't work for some reason. no big deal, we have a hw store right next door. everything is all set with that.....
just reconsidering the 6lb pulley over the 4lb pulley. dont want any problems...i am taking a trip from MA to FL in 2 1/2 weeks, and am worried about anything happening along the way.
#40
Please share the fuel system details with me so that I have them for the next guy.
#42
Actually you'll want to use a return style ruel rail on the motor itself and route the line back through undercarriage and connect it to the fuel tank where the return line currently comes in from the fuel filter. You will use a differenct fuel filter eliminating the style where it has two outlets on one side and one on the other to a design that has just one outlet on either side.
#44
#45
