engine hp Capability’s
HI!... Sure you will, you'll be slow! BWAAAA! lol! (JOKE)
Actually the turbo I'll be running will be a T-76. It's about the size of a basketball. The problem with a SC is that, if you want to change boost levels, you have to swap out pulleys and run different length belts depending on how much you want to crank the boost up. With a turbo, you simple turn a know on your boost controller and flick a switch to a different tune. To make 500RWH.P with a a sc on a 5.4, the SC steals over 125H.P to make that. The properly sized turbo only steals about 20H.P to produce 500RWH.P.
Originally Posted by Neal
...The problem with a SC is that, if you want to change boost levels, you have to swap out pulleys and run different length belts depending on how much you want to crank the boost up. With a turbo, you simple turn a know on your boost controller and flick a switch to a different tune. To make 500RWH.P with a a sc on a 5.4, the SC steals over 125H.P to make that. The properly sized turbo only steals about 20H.P to produce 500RWH.P.
