look what I got today !!!
Originally Posted by RBFC
When you drive the Whipple without putting your foot into it, you'd never know the vehicle wasn't stock. It's that smooth. You may notice the increased throttle response off-idle and that's due to having a better tune on your engine. The everyday things, like the quick lane change or pass on the freeway, are incredibly easy with only moderate throttle pressure. You could truly drive your truck without ever going wide-open-throttle (Yeah, like that's gonna happen.... ) and enjoy much increased performance anyway.
I've got a few thousand miles on mine now, and my truck drives so smooth it's hard to believe. It is always a great pleasure to get in and go, even for the drive to work.
Lee
Lee
Originally Posted by ranchocucbro
Yes, as a general rule of thumb, for a given pulley, decreasing restriction downstream (i.e. headers) from he supercharger will decrease boost and decreasing restriction upstream (i.e. intake) from the supercharger will increase boost.
Originally Posted by MeanGene
. I am not sure what's going on with my stock truck but when I press down on the 5.4 3v pedal it does not do what I think it should, if you know what I mean. Yes, press it all the way to the floor and it pulls good and sounds good too, but those minor speed changes are the ones that sort of get lost in the computer some where, maybe the F150 is thinking to hard. .
Is it worth the $100 deductable I have with the extended warrenty?
Any programmer will also eliminate the problem.
well I got my whipple put on,I'm gonna have it dyno tuned on the 21st of this month.I will post my numbers when I get it done.I hope the tune helps with the boost problems I'm having,If I floor the truck the boost gauge only jumps to 3 PSI and slowly climbs as the truck picks up speed.Maybe some of you other guys can tell me if you get full boost at full thottle??
here's a picture of the whipple
