06' 4.6 stock injectors good for 7psi??
i'm building my own version of the STS turbo kit for my truck... but i'm limited on money... will the stock injectors flow enough fuel to run between 5-7psi...
i WILL upgrade them later to run more boost, but will the stocks support what i need for a couple months till i can pick up some bigger injectors??
To paraphrase my favorite quote - at 6000 RPM each cylinder experiences a power pulse 50 times per SECOND, that's 50 times per second for engine eatting detonation to occur.
The only way for a stock injector to supply enough fuel for a blown application is to spike the fuel pressure. Your truck uses a returnless fuel system. Fuel pressure is maintained by pulse modulation of the fuel pump. The PCM controls this. Depending on how much HP you plan on producing you may be able to get a program to have the PCM spike the pressure. Just changing the injectors will not work is you do not have the fuel volume behind the bugger injectors. I suggest you find out how the supercharger companies take care of the fuel requirements. I believe they use a chip that reprograms the PCM to control the fuel as well as timing stc...
JMC
JMC
a simple "no" would have worked... i understand how the concept works... i just needed to know if the stocks would work... would 39Lb injectors suffice?
JMC
PS. Go to page 135 at this link and read; http://www.fordracingparts.com/downl...gs/2008-pp.pdf
Originally Posted by JMC
No. The question cannot be answered unless you tell us how much HP you plan on producing. Do you understand that concept?
JMC
JMC
