whats the cheapest way to get supercharged?
#31
#32
#33
#34
True and my graph shows that my truck with out the box numbers was running pig rich and The ACT spark retard was very aggressive
#35
#36
#37
I see. That original graph shows 11:1 and for good reason. Running at 8 psi you'll need at least 96 octane fuel to run safely at 12.5:1, which is where it seems like you are close to now. My guess is the tune has the timing retarded around 4 degrees to compensate for 93 octane fuel.
Whipple decided to go the rich route at the expense of horsepower to prevent damage. 11.1:1 @ WOT seems to be the magic number for many of the manufacturers.
#38
both trucks are on california 91 octane
Whipple 8psi
Powerworks on 91 octane 6-6.5psi is all you will see in stock form
In this thread is a whipple graph with stock and out the box install numbers
My truck has a Powerworks and the dyno numbers are out the box running california 91 octane with all limiter on and 22"s
#40
Can't say that since that would depend on the various factors..
What system is being used, what is the highest octane fuel available for daily use, truck location, quality of the tune.
7.75 on 91 octane 1 degree advanced
#43
#44
