Vortech Intercooler Install
Thought I'd share a few pics of something a little different. Just finished up installing an intercooler on my Vortech. Also installed a 2.5" Reichard Racing pulley and turning up the boost. Should make around 12psi... Also installed an extra pulley to allow for more belt wrap and less slip. Just waiting on my tunes now....hopefully any day it will be up and running.
Ebay Intercooler
http://cgi.ebay.com/ebaymotors/GODSP...Q5fAccessories
extra pipe leftover from ONELOWF's install. He sold me his extras and I fit it all up, everything is custom.
Spal 11" low profile fan
http://www.the-fan-man.com/shop/size...364-p-194.html
Baker Electronics Delay Timer
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220196859603&sspagenam e=STRK%3AMEWNX%3AIT&viewitem=
and connectors and clamps from Verocious Motorsports
It wasn't too bad, cut the bracket, flipped it over and cut the end of the hard lines to shorten them enough to get it to fit up. It is mounted hanging straight down now under the crossbrace rather than in front of it as it was before.
It's probably not as close as it looks in the photos, they are away from it and where they are located it can't really hit them but your right, it's definitely something I know I'm going to have to keep an eye on, there are several places I will keep checking to make sure nothing is rubbing or hitting.
Cool cooler
Derrick can you please give me the dimensions of the aftercooler the ebay listing end long ago do you by chance have the part #off the box? So with this big *** cooler you should have very little droop in psi from the blower right? and this will allow for for cooler aits ? looks very clean good job
It's probably not as close as it looks in the photos, they are away from it and where they are located it can't really hit them but your right, it's definitely something I know I'm going to have to keep an eye on, there are several places I will keep checking to make sure nothing is rubbing or hitting.[/QUOTE]
[QUOTE=derrick929;3517168]Hopefully it won't, I have two of the big flex-a-lite fans set to come on pretty early and a small pull fan behind the intercooler so there is a good bit of air flowing.
Here you go....I'm almost 100% positive this is the one, I know it's a type X Godspeed. Don't pay this for it, I know mine came off ebay for only $150 or so??? May have been $180 with shipping or something.
http://www.godspeedproject.com/store...roducts_id=217
It came from these people.
http://myworld.ebay.com/advan_racing/
If I was going to do it again, I'd probably use one like this so that you can use the silicone elbows on the bottom and turn them the way you wanted. Will give you more adjustability when you run your tubes.
http://cgi.ebay.com/Turbo-Intercoole...3286.m20.l1116
