Do I Need A New Tune
You said you were running a 2.2 pulley. How much boost did you end up getting?
If, as you say "my load and boost levels are up" and you mean that they are higher that you have ever seen them before, I would consider a revised tune unless you have an on-board Wide Band A/F Gauge.
Good point...
my boost level was the same before and after.. I had a bad/bent input shaft that took out the bearings a rubbed the case alittle
