Went to the Dyno! Graph inside!
Old 03-24-2009 | 07:53 PM
weazel's Avatar
Registered User
When comparing blowers, cant forget you have to take into consideration of each mod each truck has...
  #32
Old 03-24-2009 | 08:01 PM
IR0NS1N's Avatar
Well both the Roush and the Magna are 1.8L M112 Roots blowers, but the stage 4 port that troyer has done makes a BIG difference not so much in just peak power, but it keeps the blower at lower temps to maintain a power that a roots normally has problems with.
  #33
Old 03-24-2009 | 08:04 PM
weazel's Avatar
Registered User
Not just the port job but the more boost roush guys run. By the way magnacharger makes the roush unit.
my magna is a MP112
  #34
Old 03-24-2009 | 08:06 PM
anaheim_drew's Avatar
Originally Posted by FX4 Matt
I know mine will not hook up at all even at the track from idle will spin and at any good track you have to have a truck with ***** to do that.
Just about any Roush supercharged truck is gonna out run a magancharged truck. I have not seen too many f150 crew cabs run faster than mine
We all can spin our tires from idle so that is no big deal. What you do after that is what counts.
As far as your magnacharger bashing..........bring it on because it's really getting old.
Looking at your performance mods, post, and when you installed them, $10k spent would be a low ball park estimate on how you got your 13.6 time.
That leaves me just over $6300 to pick up 3/10ths of a second to run faster than your 13.6 in a truck not built for speed.
  #35
Old 03-24-2009 | 08:07 PM
IR0NS1N's Avatar
Well its the exact same blower. 1 PSI isnt a huge world of difference. 1PSI really makes between 10-20HP at the flywheel. Which with these trucks would probably be 5-8RWHP
I dont believe any F150 was ever built for speed other then the Lightning.
  #36
Old 03-24-2009 | 08:08 PM
azmidget91's Avatar
drew what gear ratio do you have
  #37
Old 03-24-2009 | 08:09 PM
weazel's Avatar
Registered User
don't they run 10 psi? and a port would only increase the flow so much more causing a loss in boost showing 8 psi?
More Air= More power?
  #38
Old 03-24-2009 | 08:10 PM
weazel's Avatar
Registered User
Do you have a updated track time other then the 14.0?
  #39
Old 03-24-2009 | 08:12 PM
IR0NS1N's Avatar
As I understand it from troyer he changes out the S/C pulley with a light weight pulley with the port kit. I believe it makes about 8.5PSI or so. A port will bring down the boost shown on a gauge, I dunno by how much.
  #40
Old 03-24-2009 | 08:13 PM
Like I have been telling you, here in California making power is harder for us than these guy who put our trucks down..
Example of a California built engine with low numbers.
NEW - Blueprinted JBA built motor
8:5:1 comp
Manley H-Beams
18cc Spherical Dish pistons
ported/polished heads
42 lbs injectors
ARP bolts/studs
Dual E-fans
Meziere Electric water pump
JBA Ceramic Headers
JBA Cat Back Exhaust
Granatelli Coil Packs
APM Ram Air hood
Custom JBA SCT tune
10PSI Whipple Supercharger with Fluidyne I/C
389 RWHP, 441 RWTQ
  #41
Old 03-24-2009 | 08:14 PM
weazel's Avatar
Registered User
I thought the roush kit was 8 psi stock... humm...
  #42
Old 03-24-2009 | 08:15 PM
weazel's Avatar
Registered User
I would have to agree with this...
  #43
IR0NS1N's Avatar
That truck has some seriously low boost for that set up, and shorty headers dont help at all.
  #44
Old 03-24-2009 | 08:16 PM
IR0NS1N's Avatar
It is 8PSI stock if you get the inner cooled one. However troyer changes out the pulley(s) for light weight ones if you get the upgrade kit from him.
  #45
Old 03-24-2009 | 08:19 PM
weazel's Avatar
Registered User
that's what im saying stock 8psi, 2lb upgrade = 10 lbs total then port makes it 8lbs again but flows so much more air now
so in theory more power right?
Quick Reply: Went to the Dyno! Graph inside!
