maf and fuel questions
my aftermarket what may bot be compatable?
so the 3v mafs can be used as a blow through without modification...other then a tune i mean?
your aftermarket MAF may not be compataible with your trucks ECM so check and make sure it is if it isn't the 3 valve MAF is a cost effective piece that can be used as a blow thru with the tune modification
