quick question
you can run the underdrive pulleys because the Roush SC uses a seperate drive system. As long as the replacement harmonic balancer has the three mounting holes should be no problem, if it doesnt you can still run the water pump underdrive pulley. and no problem with the E-fans you just will have to modify the intercooler tank mount.
