turbo
Old 05-02-2009, 02:56 AM
rvm's Avatar
rvm
rvm is offline
I can almost see it. . . Maybe even a wire mesh type cover on the air intake tube that goes back under the truck to keep out stones and other larger objects?
Old 05-02-2009, 03:08 AM
tj03f150's Avatar
going turbo is really awesome but going supercharged is probably much easier.
im redoing the setup on my truck, i have a new turbo kit that all i thought id have to do is bolt it in.
well...
i had to cut some of the support near the a/c condenser and radiator and so i could re-mount the radiator and a/c condenser closer to the front of the truck (as in away from the motor)
well i finally figured that out and now just have to make the brackets and THEN i can finish bolting in my new setup.
since my truck was turbocharged already well the injectors and fuel pump are already good to go.
if ur looking for a "easy" way out then go supercharger. if u have the time to deal with a pain in the *** go turbo. turbos are kickass just time consuming with all the pipe work/fabrication etc.
Quick Reply: turbo
