boost
hey drew, yo phill did you get those tunes looked at yet? anyways all the supercharger kit are pretty decent but if i was pending roush or whipple, went with roush because its the most complete kit and all the lightning pulley fit it also either way you go theres always room to get some more ponys and go faster
I wouldn't waste your time and money doing a 4v swap. These new 3v's are plenty beefy. Just slap on a super charger kit and run 8 lbs. Any more than that and you are tempting fate and will need a new rotating assembly (crank, rods, pistons, rings) Not to mention all the fuel upgrades.
Unbolt the tranny,take the hood off,remove the fan,radiator,then take off the intake-manifold,unbolt /disconnect the motor and pull it right out.
I don't think you'll here anyone on here say they wasted there money when they supercharged there truck. Can you spend less money and go faster in a Mustang? Maybe! But a truck with power is so much fun.
Especially when you blow a stage off the road.
Phil
No,,you don't have to take off the cab to get the motor out.
Unbolt the tranny,take the hood off,remove the fan,radiator,then take off the intake-manifold,unbolt /disconnect the motor and pull The harmonic balancer off it right out.
Phil
Phil
Buy the charger first keep it around 8lbs, then when you are ready rebuild your current engine, the crank is forged so you can save money there then up the boost.
