turbo 4.6
http://www.turbochargers.com/store/i...Path/21_37_215
check out this site. it will help with turbo selection and size to go with. i would suggest a 65 mm turbo (turbonetics 60-1) which will give you the power your looking for and be efficient enough to be driven to the track, spank some mustangs and drive home without too much lag. although it wont give you that 600 whp. just play around with the charts.
5 speed and 4.10 are good. a 70 mm turbo will give you a min of 550 and max of 900. be aware of lag on these. you might not hit boost till 3000 or 3500. cams might help move the power band up in the rpm range. your talking about a race truck with that size turbo. dude once you get off the line your going to be smoking! 10 seconds down the 1/4.
