turbo 4.6
well havend researched it that much and plan on building my own. but teksid block forged internals,crank,rods,pistons. probably a 76mm. dont know if i should go with on h/e air to air or what. and im leaning toward a 5-speed or 6-speed. i really dont no much about turbos just learning. i have a 03 harley too black on black so i no about the supercharger end of things. i just want to change it up thats why i want turbo and a 4.6
#1 an innercooler is almost required (for me anyway)
#2 a 76mm is way to large... skidmarkracing is pushing over 22# and he has huge lag on his built 5.4
#3 what transmission is in the truck now??
#4 you're gonna need fuel pump, injectors and a blow thru MAF
#5 talk to travis at spyder turbo's he can hook you up for $4200 installed (powder coating and tune is extra) but that includes MAF, injectors and fuel pump
Aight, I got ya now. Thats a big a** play toy ya got. Make sure you start a build thread for that 460ci. BTW, the black on black HD is sweet.
1 yeah i plan on running an h/e for sure.
2 on the turbo thats why i was askin not sure what size.
3 the trannys a 4r70w4x4. so when i put it on the 2x4 single cab im gonna have to change the trannys
4 and basically as i upgrade the harley ill be using the stock fuel pumps 90mm maf and probably the h/e unless i should go air to air.
5 this will be a long process since i never hardly drive the truck so do feel like droppin 4000 in it.
6 i just took everything off goin coilovers 2.5tons front and rear steer so that just got me for that 4000 your talkin bout. haha
![](http://i685.photobucket.com/albums/vv217/harley9703/trucks/l_ad116ee5495944489cdc00e02c624147.jpg)
![rocker](https://www.f150online.com/forums/images/smilies/rocker.gif)
