Supercharger solution for 4.6?
Is this the solution for us 4.6 guys?
http://www.horsepowerfreaks.com/part...tion_F150/7101
ProCharger Intercooled Supercharger Kits for 97-03 Ford 5.4/4.6L
I have an '05 4.6. would this work with just simple modifications?
the intercooler mounting will be tricky and you will need to modify or make new intercooler tubing but it's not too bad if you're mechanicly inclined
I'm in the middle of a write up on how to install a '97-'03 4.6/5.4 procharger kit onto a NBS 2 valve 4.6 F-150
and yes 4.6 Punisher is right a positive displacement supercahrger offf of a 2 valve mustang will bolt onto your truck as well and there a couple guys who have done so, they just don't frequent the forums much
it will physicly bolt to your engine
o and phil, your screw is the ***** as far as power is concerned
it's the front end on the NBS trucks that makes the intercooler a bit different to avoid blocking the oil, powersteering and trans coolers
my vote is for the KB but I have had no experience with them
