info on bypass[stock] valve
Old 05-25-2009, 10:08 PM
bald1's Avatar
need info on bypass[stock] valve
I am doing a lighting swap into an older 150 and need info on the s/c bypass valve, I have solenoid ,but vac. lines are not on it ,need to know how to hook lines to it HELP!
Old 05-27-2009, 11:45 AM
so you expected an instant response???
let me help you help yourself
https://www.f150online.com/forums/search.php
Old 05-28-2009, 07:22 AM
CobraKit's Avatar
Unless you went wit L ECM it won't work anyway. Plug it!
Old 06-01-2009, 08:31 PM
bald1's Avatar
I have L ECM do I need it [valve} at all? any side affects I need to watch for? will boost work ok?
Old 06-02-2009, 06:54 AM
CobraKit's Avatar
Believe you can still plug it. Recommend go on NLOC forum ans earch for Boost Bypass. Not required. As I understand it relieve boost on deceleration.
Quick Reply: info on bypass[stock] valve
