trying to put togther a twin turbo setup...
on paper
here is what I have so far
manifold $800
http://www.treadstoneperformance.com...urbo+Manifolds
they are also on ebay from the same company for 700
turbo 100-300ish for 1 off of ebay
brand size-????<---need help
I also know I need tubing but I have no idea where to get it at and have no idea of the cost
intercooler - $80
probably just this one or something like it
http://cgi.ebay.com/ebaymotors/CXRac...Q5fAccessories
wastgate - about $80
unless you know something better
http://cgi.ebay.com/ebaymotors/60MM-...Q5fAccessories
dont know enough about blow off valves yet
what else would I need to get to get this project going
the engine will be a 5.4 with all forged internals including crang shaft(stock block) also stock heads
the transmission is hopefully if it fits a zf transmission from a 02ish f250 and the rear end is from a 5.4
manifold $800
intercooler - $80
http://cgi.ebay.com/ebaymotors/TWIN-...Q5fAccessories
Wouldn't this kit bolt up to your manifolds you are looking for? If you're not concerned about price then go with an STS kit:
http://www.ststurbo.com/universal_turbo_systems
That way you can plumb right into the exhaust without manifolds.
the ebay kit seems to be something that would be a great start up kit since I can always upgrade turbos and stuff later on as for the sts universal kit it seems as though it is mounted on the bottom of the truck and since I off road every once in a while it seems that that could be a problem, on another note if my engine was in good shape I could take them my truck since they are looking for one but o well
also how do I make a down pipe
also I think they might have messed up on some pricing on their site
http://www.treadstoneperformance.com...che+996%2C+993
Good info here, it's a very deep subject........ http://www.theturboforums.com/smf/index.php
from what I have read(and it might be outtdated) is that with two turbos you get boost throughout the rpm range which give you more low end horsepower and highend where as one big anus turbo will give you much much more highend horsepower, also with the twin the way i have read to set it up was to run one small one and one medium one so once your rpms get to a certain point the medium one takes over where the small one left off, also two smaller ones are much cheaper than one big one from what I have seen
If you think about driving WOT, sure from a dead stop you will have a delay in spool time, but with a V8 pushing a big turbo it the lag wont be as bad as say a EVO or something. Plus at WOT your truck will be over 3500RPM every upshift so you wont ever experience lag again during the run.
Either way, twin turbo or single, its still a turbo set up and aint no one going to give you nothin but respect.
Maybe in a junkyard. You can buy a very big and capable single turbo for around $500 (BW S475 comes to mind).
Keep this in mind: The 5.4L can spool a very big turbo for its displacement. At 330 CID it'll pump up a turbo faster than any SBF or SBC of equivalent displacement. Don't get hung up on some outdated modes of thinking where others will say a 76mm turbo is too big and will lag. It isn't and it won't on these engines. You can probably find a very good deal on a small, medium, or even large frame turbo in the 70 - 80mm range that will support plenty of power with room to grow, be cost effective, durable, and will spool plenty soon enough to fry the tires at will.
It is a myth that twins spool faster than singles. Twins are generally better when you have less room to run tubing because there are no x-over tubes. 330c.i. is not a lot of displacement but with a properly matched exhaust A/R, will spool up quick. People will talk turbo lag, but if that's the case, there housing is not matched to there combo. Just as a example, I'm running a 76mm on a 6.0L, that's only about 30 more C.I.s, with a .96A/R exh. I'm also running a 3400 stall converter from a previous combo. which is a little to much. It achieves full spool at a little over 3000rpm. The trick is, you want your stall speed to be just before your turbos spool time on a street motor where your not in boost everytime you go half throttle to merge or pass because gas mileage and street ability will suffer. There is a bit of science to it but the outcome is just sick
76mm. is plenty for the street because it still has good spool time for that many C.I.s. Just depends on how much power you ultimately want to make. BEFORE you start, that's the main question you want to ask, along with do you want your power to come in low rpms for towing and mudding, or do you want a high revving eng. where it comes in later...? Don't just throw one on or you could end up like those stupid import guys that have to get on the interstate at 80+mph. and can't race a go cart from a dig at a red light.
The 5.4L will spool up a 76mm faster than a 6.0L. It's not the difference in cubes...it's the difference in stroke that's key. I wouldn't be concerned about lag running a single PT88 on a stock headed 5.4L. If keeping with a budget build then look at the Borg Warner turbos. T6 flanged 75mm turbo for less than $600 brand new if you don't shop around. Support all the power you could want and are very durable. Definitely the route I'm going with my truck.
We did a 88mm on a stroked 4v Cobra Aluminator motor in my shop a few months back and through stock cams with virtually no overlap, spooled at almost 4000rpm. That's why I asked the the question, how much power do you want to achieve? An 88mm will definitely make more power, but if 6-700hp is what you want, then an 88 would be a stupid choice when a 76 will make that,(Mine dyno'd 645@ 10psi.) and spool sooner which is what you want for the street. All I have to do is take off my 76 and bolt on the 88, but it would be pointless because even running around with slicks, I still can't put the power to the ground, and it takes longer to spool. And the 76 makes more power than I can put down on pump gas.
And definitely stay away from the El cheapos and stick with the more efficient turbos like Garrett and Turbonetics. If you want to spend a little more on the ball bearing turbos, they will come in a hair quicker but they don't make any more power.
