Supercharging a 2003 F-150 Boss
Old 07-16-2009, 08:38 AM
CobraKit's Avatar
Looks like you'll still need the:
- Fan shroud
- water pump or fan spacer
- throttle cable
- injectors
- maf/boots/air cleaner
- 255 fuel pump
- modified NA wire harness
- L alternator and bracket
- Brackets for IC heat exchanger (or make some)
- 4 IC water hoses
- new heater hose (old one went to front of water, new ones goes to rear)
- new front radiator hose (could use old one)
- EGR line from manifold to blower
Just to name a few parts
  #32
Old 07-16-2009, 03:26 PM
Her2001's Avatar
- Fan shroud Got that too but I would go Navi Water pump and use an E fan
- water pump or fan spacer Got that too but I would go Navi Water pump and use an E fan
- throttle cable
- injectors Go new
- maf/boots/air cleaner Go after market
- 255 fuel pump Got that too for $100 more for a new one
- modified NA wire harness Just use the stock harness
- L alternator Got that too and bracket I have an Alt but no bracket
- Brackets for IC heat exchanger (or make some) Included
- 4 IC water hoses Should be in picture
- EGR line from manifold to blower Most ditch the egr- I have a billet block off plate
Added some more info
  #33
Old 07-16-2009, 09:49 PM
150xlt's Avatar
Originally Posted by built54
yeah thats pretty complete right there.
I agree^^^. This would be great for someone that doesnt want to spend the time gathering parts. I didnt click the link for a price though but it does look pretty complete.
  #34
Old 07-17-2009, 07:20 AM
CobraKit's Avatar
  #35
Old 07-17-2009, 01:06 PM
Her2001's Avatar
Better check first. That's looks like a 99-00. Different bolt pattern for later blower swap and the problem Inter cooler with less rows. This is to much of a job not to do it right the first time.
  #36
Old 07-26-2009, 01:53 PM
grvv's Avatar
I have an intercooled S-trim Vortech and I made 450hp at RW, will be more with different maf. I will be selling the Vortech in 3 or 4 weeks.
  #37
Old 07-26-2009, 03:37 PM
grvv's Avatar
The S-trim has a whine to it so when your idling along poeple know you have a S/c
Quick Reply: Supercharging a 2003 F-150 Boss
