Project high 14s with a vortech V1
Sorry i redirected that question to darrick. Im thinking very hard about going to this water to water set up off ebayhttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270393123624&viewitem= &sspagename=STRK%3AMEWAX%3AITIt has 3.25 inlet out let and comes with a fan to blow on it. I would use a plastic res some where under the hood and get a little eletricwater pump to creat flow and run it with 40% iso alchol or coolant so it wont freeze this winter it only 10ins in size and has a bung for a coolant temp sensor. Its almost like i have a bad taste in my mouth about all centr after having the superdyne. I want to wait and see if this v-1 changes my mind about them so ill probley wait to see what the v-1 does on the cooler i have now so im not buying things 2 and 3 times over. It sucks to come up with a better idea later and have to buy agin i know ive done it lots before.
nonwoven29,
Any update on your system? Did you ever find the intercooler I had? Just for reference, I was datalogging the other day, I think I had 91deg temps outside and with 12psi from my upgraded V1 SI, I was seeing only around 110 deg intake temps. I've since added meth to lower that even more.... The Ebay Godspeed intercooler I bought works great!
