whipple, magnacharger, or roush
I have a 3.125 Pulley that I bought from Troyer Performance (I couldnt find one), I have 47lb injectors that are out of a GT500, but you need a fuel injector cap because they are a half inch to short but plug right in. Stock Whipple MAF. Brisk Racing plugs at 30/1000s (also from Troyer)
If money allows (ive spent alot lately) I hope to get on the dyno this winter.
Well think about it, 39lb injector is out of a 4.6 DOHC supercharged motor making 390HP.
47lb Injector is out of a 5.4 DOHC motor making 500HP. If my truck makes 500-550 Crank HP with a 5.4, why would I go with an injector thats on a car with 400hp, 4.6 so smaller displacement, and cost the same amount of money?
I plan to get troyers Dual hat fuel pump set up thats good to 500RWHP. Then expand to the tripple hat good for another 500RWHP after that.
I got mine through http://www.hollywoodracing.net/ through a guy named Matt. They are just like these but purple. http://www.fiveomotorsport.com/Injector_CONNECT.asp Troyer can do a data log tune for your truck so you dont have to drive to VA to have it done.
what about these 39lb cobra injectors i see ppl talking about? what year cobra are they out of and how much grinding is needed to make them fit? seen a couple whipple guys talking about a cobra maf housing as well? im also starting to get concerned about needing to upgrade the pump to go to 10 psi, how many of you are running 10psi on the stock pump? sorry for all the questions just really want to do it right the first time
Thats what were talking about, the Cobra 39lb injectors. You have to do some shaving in order to get them to fit. Its not much but you do have to do a little modifying. I dont know to what extent as I went GT500 Injectors. Cobra injectors these http://www.fordracingparts.com/parts...tKeyField=5941 off the ford racing web site. Fuel pump will be fine at 10psi. With a after market fuel pump you can open the throttle plate more and dump more fuel in for more power depending on your tune. Also, it lets the fuel pump work less to pump the same amount of fuel.
Size of MAF doesnt really matter in a way. All it does is read the voltage on the wire and according to that voltage it will tell the PCM how much air flow is coming through based on the MAF housing size. 95MM wouldnt hurt on a 8PSI motor or a 10PSI motor. They make a 120MM for the GT500 along with massive throttle body which would be good for higher levels of boost.
Theres alot more to it then that, but really 95MM is fine for 10psi
