Lower overdrive crank?
I pinged ASP in Texas, they say they can modify our stock harmonic balancer from "6.625 to 7.00 with minor timming cover modifications". I do not know what size ours is but it doesn't sound like too much of an increase or is it? I measured what I could reach, which was the front of the dampner and got exactly 7 inches, but I noted the area where the belt wraps around is smaller in diameter, so the belt is just about flush with the front facing part if you were to look at it from underneath, not sure of how much of an increase percentage or boost wise this would be, but they said they can bump it up...
i know it says 4.6 but it should fit the 5.4 also plus its the cheapest i have found hope this helps
http://www.teamjdm.com/shop/product_...roducts_id=276
God, i hate that screen name makes me clinch ever time i read it... haha, but any how.. yes i checked into it, spoke to Jim Jr. from JDM and it will not fit due to the offeset. they tried it on a truck with a 5.4 and it didnt work..
I am thinking its 6.52, I have my stocker in hand and using some insulated wire (something I had near me at the time) I laid it down in one of the belt grooves and wrapped it around in the groove to figure out the circumference, (I don't have any calipers), with my tape measure and wire I am showing about 20.5 inches. My version of math says 20.5 divided by 3.14 gives me the diameter of 6.52xxx". I will get ya the diameter of my dampner I just got tomorrow when the sun is out, its dark right now and the skeeters are on a rampage right now. The front facing weight part is 7 inches.
