Vortech Question
yes I am running an FMU. also just changed the fuel filter two ago. I removed power to that inline fuel pump and the truck ran the same with it off. (Just did that for testing purposes)
Do you have a part number or location where i could get the fuel pump you recommended?
thanks again for all the help!
If you unhook the power to the in-line pump. Wouldn't that cause a restriction?
I don't know, never ran an in line one.
I run 2 Walbro's in my truck. This is about the cheapest place to get one.
http://treperformance.com/i-788624-f...1997-2002.html
Phil
Phil
YES, if the inline pump has no power or has failed then it will be causing a restriction
since your starting on the fuel susyem anyway, see if you can finda set of 42# (lightning/Harely truck) or 39# ('03-'04 cobra) injectors and a ford SVT 90mm MAF
then have your truck tuned, it made a world of difference on mine VS the FMU
