4.2 supercharger or turbocharger?
I'm sure this is probley an old subject but I cant seem to find an answer anywhere. I have a 2002 f150 with a 4.2 V6. I want ether a supercharger or a turbo which ever would be better. I'm looking for more low end power. I was thinking of a tuner but IDK how much of a difference that would make. Alone that is. So sorry if I'm digging up old news but I would like to know if a kit exists and where to get it.
there was/is a company that makes an adapter plate for the lightning eaton and that alone is 900 plus the charger and all the other parts looking in the 2500 plus range. but it can be done. its almost like how the mustang guys do FI on the 3.8 v6. similar motor but it has rightside intake and not driver side like the 4.2 and trucks
Since when would a eaton adapted to a 4.2 only make 4 PSI? Maybe it would only make 4PSI at like 2800 rpms, but all you would have to do is get a pulley and all of that changes. Even if you arent running fuel upgrades those dont effect your ability to make boost.. they only affect the ability to mix the gas efficiently into the boost to make good power out of it.
If a procharger would work on a 4.2 the only "fuel upgrade" he would need is a boost-a-pump which take about a whole 5 minutes to put on. After that a FMU would need to be installed, but whoop-dee.
Turbos have the ability to spool up to an insane rpm so turbos would have no problem running 4PSI or 30 for that matter. Its all a matter of what the engine can handle because theres no way a stock 4.2, much less a well built one, could handle 30 PSI very long. And trust me.. if you can find an engine that can handle that then you wont find a tranny that will.
Also, not to beat a dead horse, but why do you insist on throwing out how fast your stock v8 singlecab is? You are boasting about 200 horsepower like your have more than every one else, and I dont understand. Its not like this guy ask to race you or anything.. he just wants to know how to make some good torque out of his 4.2. A supercharger or a turbo could EASILY do that for him provided that he can get one for his engine. I wont sit here and try to act like I know it all, but I just personally installed a procharger and have been conversing with tuners and other people with S/C's on their trucks.. so I think I have a run around. I have plenty of power adders on my truck and you wont see me going around running peoples noses into the ground when they try to get a simple answer. Let your truck do the talking my friend.. no need for you to.
You get me so confused when you speak...
On a stock fuel system a 4.2 can only run 4 PSi stock.
Single cab V6 5 speed with e-fans and smaller tires than you got spanked by me. I dont think your tuner makes up for your half cab and if it does then not by much. Dont worry little buddy I'll be up there soon Alex. Hopefully.
Um.. okay. I gave you safe PSi to push w/o fuel upgrades, and the company that makes the adaptor plate (w/Jakes help). Blue-oval is Ford dumbass, all im tring to say is for 5k dollars you could do a motor swap, and build up a V8 that will sound good.
Dude... wtf. I just took the time to explain to you that the "stock fuel system" can do what ever the **** it wants. It has nothing to do with making boost. Boost is a measurement of the mass of air being forced into your intake. You can run 648 PSI on the stock fuel system if you wanted to.. but it wont be able to keep up with the fuel air ration.And besides.. after he has spent 5k on this sick turbo or s/c set-up then who really cares about getting new injectors or a different fuel pump. All that stuff is minuscule comparatively to the work, parts, and prices involved in a custom set-up, which is exactly what any kind of FI would be on a 4.2.And just because he has a 4.2 doesn't mean he cant make good horsepower or torque. Who told you that you can only run 4PSI anyways?
