Amsoil Signature Series extended mileage use?
#31
They don't push extended intervals to justify the higher prices, the push the intervals because the product is bult, capable, and up to the task. Guys like you focus on the sticker price when in reality, if you use the product as intended, it's actually cheaper than most any other route.
If this is a spot of contention for you, then Amsoil has a product to meet your needs, concerns and desires. If you are smarter than that, and know enough about oils to not be worried about the cert, then Amsoil has an industry leading product for you as well.
http://www.amsoil.com/news/2008_worr...warranties.pdf
https://myaccount.amsoil.com/Dealer/...nusonMoss.aspx
And what' the problem with doing this?
Some engines are more prone to sludging than other engines. VW and Audi have these engines, so they developed their own test and specs for oil
sludging. Here are the oils that PASS their tests:
http://pics.tdiclub.com/data/500/vw_tb_17-05-04.pdf
http://dejong947.com/audi/tsb/audi.tb.17-05-01.pdf
Notice there are NO Scamsoil products listed, but Mobil 1 is.
#32
WOOOW...you say this so negatively like it's some big dark secret you just revealed for the first time like some tabloid news flash.
Completely irrelevant that Amsoil is not on this list. They probably didn't pay to be on this list.
I have found it's a lost cause to argue with people that have been brainwashed by Scamsoil.
Like downplaying API certification, and then recommending XL (which is API certified) and adhering to manufacturers OCI in harsh applications.
#33
I have seen these arguements before on other forums. It does seem that with Amsoil it is love or hate. Kinda like the ladies arguing over Mary Kay lol.
While I am on the fence with the stuff I must say no tuner nor engine builder nor racer has ever said to me to run Amsoil. While they have all said use Mobil 1. Just a thought.
#34
Ahhhh, it's OK dude, we understand. We'll call a draw cause we feel the same way about you non-conformist ...who continue to bash the product for no profound apparent reason beyond a lack of understanding; despite all the positive, supporting, evidence to negate all your negative claims.
#36
Having said that, if I didn't already have a (very expensive) remote filter that allows me to run a very large conventional filter, I'd have one just for the cool points and added capacity alone. But that's just me.
#37
I'll try to keep on topic here by saying a bypass system will help in efforts to extend drain intervals.
#38
The filter is a great addition to extended the change.
But I still have the oil to worry about first...
I've been running motorcraft blend since the beginning, from my previous research in the past my conclusion was its a rather superior product compared to many others. That was just my conclusion though.
#39
^ Yep, you can't take hamburger and make it a steak no matter how many seasonings you put in. But that steak would taste even better with a marinade. Sorry for the analogy but it's my best way of relating it to oil. A poor oil won't get better with filtration, but you can keep a good oil going better. Motorcraft (Conoco Phillips is the manufacturer) makes a pretty stout blend, there are oils that may hold up better in your application though. Do a UOA with what you've been doing and get a baseline of where you're at. If it's not shearing, changing grade, etc and you still have enough TBN to go longer, go longer. Don't fix it if it isn't broken, but if you have no way to know you're just shooting in the dark. If you find the oil isn't holding up over what OCI you want, then find another.
#41
#42
So I have spent quite a few hours over the past few days looking in to Amsoil and trying to compare it with other oils. And I am no longer on the fence. I think its buttload of crap in a bottle for a high price. Now I'm sure the supporters will fire all sorts of "facts" and "test results" at this thread. Don't bother I have read and read and read till my eyes are crossed. Heres why I feel this way...
In all the searching and reading I have found website after website with names like alternative energy resource, smart synthetics, synthetic lubes, ultimate synthetics, and on and on and on. All with comparision test performed by an "independent lab". Every phucking page the same. Amsoil wins on every possible level against everybody tested and before long you realize you have been reading a bunch of Amsoil propaganda. And eventually the hook line and sinker, "to order amsoil"...Bull freaking crap!!!!! Even in test where the Amsoil didn't win on every level it is the only oil mentioned in any comments with the test. Now if this test would have been done by a real independant lab you would see comments on all throughout. For example when Motortrend compares cars or trucks. They will tell you pros and cons of each or at least how two performed equally well. Oh but Amsoil has no cons. Again BS! Funny also that when Amsoil doesn't show up for a test its because they didn't pay to be in it. Again BS! I'll not give this company my money for the simple fact they have far to much propaganda preaching their gospel according to them and suckering people into their pyramid little cult. Snake oil and very expensive at that. Rant off.
#43
#44
+1 Now you can see why I use the term "brainwashing" earlier!! The pyramid marketing scheme company prey on the "weak"! Another thing
Scamsoil is good for is deception! They will put the API certification code
on the bottle label, when the product isn't API certified at all!!
Here are a couple good articles on Pyramid (mutli-level) marketing companies:
http://www.falseprofits.com/MLM%20Lies.html
http://www.scamwatch.gov.au/content/...PyramidSchemes
