harley swap to an n/a 01 2v 5.4
1. If i have the stock vacuum lines from a harley complete with boost solenoid and all those sensor connections can i still use my na harnees which is already modified to reach iac tube etc... Or do i have to swap the harnees to a harley harness as im going to use boost solenoid with all the sensors that it comes with and with harley vacum lines?
2.can i use and aftermarket hub with a pulley ring for my crank pulley ot would i need the harley harmonic balancer to make it work or would it bolt on perfectly as mine is an na 5.4 ?
If you have HD vacuum lines, why not use them? You can use either electrical engine harness, just make sure you tell your tuner which IAT your using. Also, when you buy aftermarket lower pulley, you need the ring that goes between that and the NA hub. Call up one of the companies and tell them you have a 99/00 L, those used NA hubs, newer L/HD had a larger hub.
i will be using the harley vacuums and will be using my na harness iat would only be one. my questions here is how do i route my vacumm line as im going to have to delete the boost solenoid and the barometric sensor as my n/a has no connectors available for those 2 sensors
and i bought an lfp #2 lower crank pulley hope i dont have a problem with that hub that came with it
and what belt can i use on this?
stock harley upper pulley
stock idler pulley
and ofcourse #2 lower
i believe is 66.5" to 67"
where can i get that correct size belt?
If the LFP pulley was for 01-04 L it will bolt up, just won;t be hub centric. I would guess that LFP would sell you the hub centric ring for a couple bucks. It keeps the pulley concentric with the NA hub. Same pulley!!!
As for vacuum its been 90K miles since I swapped the blower on. But I do have a vacuum schematic if you want. Send email.
