06 sc on an 08
06 sc on an 08
Good afternoon guys.
I have an 08 limited awd and I am looking to put the roush sc on it from an 06 that I purchased and ya led the engine etc just for the kit.
i have started the process, how ever i noticed that on the lower plenum is the bypass control solenoid, and vacuum lines. The 06 donor harness has a plug for the solenoid, however my 08 does not.
should i/ do I need to swap the donor harness into the truck? Or is there ways around this?
its been a long time since i worked on this project, and i finally got a wild hair and want to get it going. Im at a stand still with lower plenum because of this issue. Any help or direction would be greatly appreciated.
I also realized that the 08 fan hub is larger than the fan hub spacer I have off the 06, is there an option available for the larger hub? Or should I swap hubs on the water pump?
So this is the current situation. The engine in the 08 has low compression, the cylinders are scored pretty decent, so I have ordered a set of sealed power hyper eutectic pistons and ring set .020 over bore. I need to order the h beam rods, the heads have been rebuilt and had bearings installed in the cam tunnels, new cams, new lifters, etc. 3 angle valve job. And decked back true. I have all new bearings for the bottom end and arp main studs, rod bolts, and cross bolts.
also waiting are head studs.
I will probably gasket match the intake and the heads. Is there anything I’m forgetting ?
