front end leveling for 4x4
I have a 98 f-150sc 4x4 that I would like to level out the front end. Is turning the torsion bars the best way or will this lead to problems with alignment or anything else.
I suspect that it would only take 1-1.5" to level the front. If anyone has any ideas or knowledge on this that would be cool. thanks
Yep thats the best way to do it. When you only raise it 1 to 1.5" you shouldn't have any problems. If you raise it more than that you will most likely need to get an alignment.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
285/75 R16 Kelly Springfield Trailcutter RTs
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
http://www.powerstroke73.homestead.com/
1997 F-150 Lariat
Ext Cab Short Box
3.55 Gears
My 2 cents worth
Okay how do you attempt to raise the front i mean where are the adjustments made under the truck??,. I did this on a duster i had and it was easy just turn the bolts.
1997 F-150 XLT 4.6 shortbed REGULAR CAB, FLARESIDE CLEARCOAT GREEN 5-SPEED. WESTIN NERF BARS, POWER EVERYTHING,BUG SHIELD, EX-TANG SOFT COVER, BED LINER(FORD).
Better 1/2 : 92 Red T-Bird V-6 3.8. maint.free 113,500 miles
Thanks Powerstroker!!! I leveled it a couple of days ago and only needed about 1". I'm stoked it looks much better.
1998 F-150 supercab shortbed, 4.6 auto.
Magnaflow exhaust 3", K&N filter, Leer canopy
265/75/16 STX All-Terrian on Eagle 143 16x8
should of went bigger on the tires!!
