2" of lift, new shocks?
Raising the torsion bars on the front will not require new/longer shocks because even though you are 'raising' the front of the truck, you are NOT changing the geometry of the suspension nor are you changing the length of the travel. As for the rear, I do not know. It depends on where the leafs mount and how it affects the location of the axle.
No "possibly" about it...They WILL overextend, and you don't have to become airborne for that to happen. The right articulation will accomplish that. You would definately mess up a shock or shock mount if enough stress or hard enough hit was encountered. By changing the blocks you didn't change the 'travel', but you did change the geometry in the form of the distance from the shock mount on the axle in relation to the one on the frame. That distance is increased at the point of full travel and that's where you will overextend and mess something up. Guess if you stay on the highway you'll be OK though. Good luck...
I have bilsteins shocks on my truck...in my humble opinion, they are the best shocks ever made for our trucks. I raised mines 2" in the rear and the folks at bilsteins recommend changing the rear shocks out with their extended shcoks if you are going to raise the rear 2 or more inches. I purchased their extend shock and could tell the difference immediately. I discovered my old shocks were extended all but 3/4 of an inch after adding the lift. With their extended shocks, the ride is great.
