Front end leveling
Front end LOW
First of all, welcome to F150online from Canyon Lake, Texas!
Yeah, my '02 S'crew is about 2" lower in front than the back. If you use "spindle" lift, you'll probably need a lift block in the rear to keep it level. Daystar is available in 1.5" to 2.5" spacers for the top of the coil spring. Then there is the "replacement" front spring w/upper control arm. Seems to me the "spacers" are the "simplist". I need (or want) to do the same to mine, just have not gotten up the money to do it. Good luck!:thumbsup
