question about torsion bars
I bought my truck used. Since I bought it the only "modifications" I have made to it are some Rancho RS5000s that I just got for christmas.
In any case, my question is, is there any way for me to tell if the torsion bars have been adjusted by the previous owner? I looked at the screw and they do not look to be even (but for all I know they are like that from the factory...I have heard of them not being even after adjusting them).
Thanks.
Thanks.
About the only thing you can do is look at the bolt used to make the adjustment. There's no sure fire way to tell where it was set from the factory but I can tell you it did not come cranked all the way up. Most likely about 1" of thread showing would be a factory setting. If it's all the way up (bolt ran in completely flush with no threads showing) it was adjusted by someone. Also, it is not very likely that someone at a shop would even touch these while working on it or aligning the front end. They are not used for this and do nothing to align the front end...except of course un-aligning the front end when you do it yourself. That's why you should get it realigned if you raise (or lower for that matter) it any.
