Warrany Alignment?
Warrany Alignment?
I know some of you guys out there have had you trucks aligned under warranty, and some even got them to throw in a set of camber bolts. My question is was there a limit (time or mileage) as to when you could still have this done? I was told 12,000 miles was the limit on brakes and alignment...
I had it aligned at around 10,000, but that didn't fix it, and I've now waited about 4 months to do anything more. Just don't always have time to just let go of my truck... and it now has over 15,000 miles on it. They told me that I should have said something within 45 days of the last alignment, which makes sense...
I plan on getting the camber bolts, and having a good shop do it this time... but thought I'd check on this first...
yes/no?
thanks...
yes/no?
thanks...
Well, what I'm trying to say is, they tried, but did absolutely no good. It's just as bad as it was before they did what they did, just pulls the other way. I guess I need to rotate my tires, since I think they did that at the time, and see if anything changes, it's time anyway... Then go from there, but if I have it aligned it will be at a local shop, and I'll put camber bolts on first...
