Modified Lower Control Arms
Some time ago I read about a shop, I think in Michigan, that has a technique for modifying the lower control arms and spindles to lower your truck 3" with the stock springs.
I want to look into having this done but now I can't find any info.
Anybody know anything about this?
You are reffering to DnD Customs here in Michigan.I will try to find the link to their website.The only thing is after flipping the lower ball joint, you cannot run anything SMALLER then a 20" rim on the front.I am currently modifying a set of OEM stock lower arms.I cut the spring pocket out and welded in a 2" collar to lower the pocket.Going to combime that with 2" drop coils for a 4" drop.I have Chassis Tech upper and lower control arms now, but the lower arms rub on teh spindle, allowing me to not be able to turn the wheel all the way. But I will PM you the link when I find it.
.....Rob
.....Rob
