How To Adjust Torsion Bars???
Follow the torsion bar toward the rear...there should be a bolt on each side for each bar, just tightin them clock wise and watch front end rise
It will ride rougher and wear things quicker but its your choice.
Hope this helps
Jimmy
www.ftwtrucks.com/1HIGH4BY/
https://www.f150online.com/galleries....cfm?gnum=3950
Hope this helps
Jimmy
Yes if you raise them enough then it will throw off the camber and will require an alignment. With 1.5" I'd reccommend getting it checked. Usually if you go with 1" or less you won't throw it off enough to cause any problems. There are a few other drawbacks to this. One is the stiffer ride. When you crank the torsion bars up you're essentially increasing the spring rate of the bars so you have a stiffer spring. This is what causes the rough ride. Aside from that the other drawback is that it moves the ride height of the suspension lower in the travel path. This means that theoretically it will compress more and have less droop. This isn't much of an issue since the factory IFS doesn't move very much anyhow, but depending how much you raised your front you may run into an issue of being limited by the shocks and the CVs.
