Ranger Lift???
www.4wheelparts.com
www.fabtechmotorsports.com
awesome forums
www.mintrucks.net
www.rangerpowersports.com
is it the edge or just the regular ranger?
I used to own a SVT contour then it started falling apart...
awesome forums
www.mintrucks.net
It is a regular xlt 4x4. yeah i just got rid of my car after putting alot of money into it. had the trans all beefed up and alot of mods done to it. check it out here http://www.pbase.com/silversvt/inbox
Yeah those SVT's are pretty cool but I feel that the build quality is ****. My dash was lifting about .5" when I traded it on a WRX.
Mine was modded nicely
CAI, Superchip, B&M shifter, Different Exh, 18"s, lowered, and a bunch of other crap.
Well hopefully those links help you on your journey to liftdom!
Try RCD,BDS, and skyjacker. I just sold a 1993 ranger x-cab auto 4x4 with 9inches of lift..i used skyjacker 6" class 2 system it run me about 2000 i believe..and a pa body lift...also check this site out..the best site ever for ranger owners... www.therangerstation.com ...i owe alot to those guys.
l8tr,
Bada$$1fitty
l8tr,
Bada$$1fitty
trucks!!
On Truck!! the tv show they lifted a new ranger buy using a shackle lift in the rear and adding more tension to the bars in the front. I don't know how must wear that will add to the front end but it allowed for 2.5" of lift and I think some 33's.
Good luck!!
Drew
https://www.f150online.com/galleries....cfm?gnum=3761
Good luck!!
Drew
You should be able to get 1.5"-2" with a torsion bar twist. I'm pretty sure several companies (Rancho, Superlift) make suspension kits for the 95-01 Explorers, which are very similar to your '03 Ranger. 4Wheel Parts Wholesalers (www.4wheelparts.com) had a Superlift SportTrac 4-inch lift listed for $1800 (again, similar). Either the Ranger Station or Explorer 4x4 site should be able to give you info on what you need to change/modify to adapt an Explorer kit to your Ranger.
Body lift is your other (much cheaper) choice...
