Ball joints worn out already?
If and when you get the parts replaced get the greasable ones and make sure you get a lifetime warranty. They will wear out. I have Moog uppers. The lowers are going to come out this summer and I will be using Moog again. The front tire is so heavy that to properly see a worn out ball joint you may have to remove the tire and pry the sucker with a bar. Same goes for the lower.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
