Difference of 7700 vs. standard F150?
I am wondering what the differences in the front end are between a 7700 package and a standard package on an F150. I know the 7700 have the 7 bolt wheels, larger brakes, and a tranny cooler.
What do they do to the front ends to allow them to handle a plow?
My dads 7700 would never squat under load, are the rear leafs any different? Appear the same (4 x 2.5")?
Now as I recall the front uses the same axle (8.8 RR IFS) as the standard F150. It just uses different outters. The reason it can hold the weight better is they use a different torsion bar. They are significantly larger than a standard torsion bar. And FWIW they will swap into a standard F150.
Looks like 7700 gets larger brakes, tranny cooler, 10.25" rear end with 3.73, larger altenator and radiator, and as mentioned torsion bars that will swap right into a standard F150.
Looks like I can add a leaf in the rear, swap out the torsion bars, and add a Troyer Performance tranny cooler (will put in dual pod column with temp guages) and pretty much have the 7700 package (minus the larger brakes and rear end and gay 7 bolt rims...already had the 3.31's changed to 3.73's )
After adding RSX9000's, skidplates, and decals I will have a 03 Scab with a custom made 7700 and FX4 package...something that was not available from ford.
