New Upper A-Arms = Harsh Ride?
I recently had to get new upper A-arms installed because the ball joints wore out (they are all one piece) and now my truck's ride is terrible! It vibrates and shake a lot. Was there something the tech did when he installed them that could have caused this? -Thanks
There could be a few things wrong here. First bet is he did not lubricate the bushings in the new A-Arms and thus they are binding up and not allowing th suspension to move. Second, he could have over tightened the bolts also which would cause binding. It could also be he did not do a front-end alingment and the truck is out and thus doesn't drive the way it should. I'd take it back and have them check all those things I mentioned.
I recently also replaced the upper and lower a arm ball joints to some heavy duty MOOG's when I had the energy suspension bushings placed into the a arms. I also had the sway bar bushings installed at the same time. I only have have experienced a squeaky sound from the bushings since they are polyurethane even though they are greased up....well good luck with that and nice muddy rig you got
next project stoptech big brake upgrade and ATI procharger SC
01 4.6 4:10 gears LS
24" Katana Azzad's/ 305/35 kumho
Flowmaster 40 original w/ dual outlet
pro comp 9000 shocks (fr)
pro comp 3000 shocks (rear)
rancho 5000 stablizer shock
Hellwig rear anti-sway bar
Front A- arm and front sway bar-
polyurethane energy suspension bushings
BBK 75mm TB
BBK pulley set
Moog heavy duty ball joints (upper and lower)
K&N Kit GEN II
Power programmer III
HD lower valance
HD speed tubes
Viper remote start 791VX
BBK 75mm TB
BBK pulley set
K&N Kit GEN II
HD lower valance
HD speed tubes
