daystar lift for 4wd 2004 150
Im adding a daystar 2.5 lift on a 2004 4wd super crew on monday, does anyone have any pictures of this done with or with out stock tires, Also any info of tire size that i can run on this truck.......any one have experence with weld 18" XT wheels(renegade ,velocity or chyenne), size off set etc...Thanks for the help.
Rod
Rod
Several people here have added the Daystar lift. You might want to post this in the 2004 forum, as that is where most of them hang out. I have seen people run up to a 315/70-17 (35x12.50) with this lift by using the stock rims. I'm not sure what backspacing everyone is using on the 04 wheels, but the 8 or 8.5 width wheels seem to work the best. Most of the 10 inch wide rims I've seen on 04's appear to stick way outside the fenders. If you are gonna use an aftermarket wheel, you may be better off sticking with a 33 inch tall tire.
