raising front
jack the front of the truck up from the frame and let the two front wheels hang, screw in the torsion bolts but don't bottom them out on the crossmember, lower the truck, back up, pull up, measure the same spot on each side of the truck to the ground, if = go get an alignment, if not adjust properly then get an alignment
