lift for only the front
is there any way that i can buy a lift kit only for the front of my truck b/c i found a cheaper way of lifting the back of my truck all i will need is a lift on the front of my truck so if you have any way i could get a lift for the front please let me know!!! thanks a ton
Like I said, most lift kits come with lift blocks or add-a-leaves for the rear unless you pay extra to get a set of replacement springs. You won't be saving any money by purchasing lift blocks from the parts store. Also, they won't come with any shims to correct the pinion angle like most lift kit manufacturers include in their kits.
Don't cheap out when it comes to the suspension. If you want to save money then don't lift it. As was mentionned lift kits come with the required parts to correctly lift the truck. You will in fact be paying more for parts that are already included. While I do not condone blocks they are used in most kits which also offer an optional replcement spring or a helper spring. When I finally get around to adding a suspension lift I will have new rear springs fabbed up to replace the factory ones. I do not like blocks.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
