Best Way to get 4 inch lift on 2wd
A 4x4 sits approximately 3 inches taller than a stock 4x2.
You have several options for an inexpensive lift.
First you could add a 3 inch body lift. You could also add a set of 2 inch Daystar coil spring spacers to the front, which would get the front close to level with the rear. For a little more money you could add a set of 3.5 inch lifted spindles. The body lift and lift spindles will not affect your ride at all. The Daystar spacer will make the initial portion of the front suspensions travel slightly stiffer. Of course, you could combine all three for approximately 8.5 inches of lift.
