What size U-bolts???
I am planning on adding a 1" block to the 2" block on my 97 ORP. I figure a U-bolt 10 1/2 inch U-bolt would probably be long enough...but how is the width measured inside to inside or center to center? I need to figure out what I need before I head to autozone with a tape measure! Thanks
From my experience autozone doesnt carry UBolts for the axles, only for exhaust work.
What you need to do is call a company in santee, california called National Spring Co.
I think they have a 1800 number... but they do that stuff all day and they will tell you your exact size
This is the lazy way by the way... the better way would be to get under your truck with a atape measure... they are measured from center of stud to center of stud, and from top of arch to bottom of stud.
