Grease and oil for rearend
It's real simple. If you have a limited slip rear end, you buy the bottle that says "Specifically engineered for limited slip rear ends". This means that it already has the slip additive in it. If you do not have a limited slip rear end then you buy the regular 75w-140 lube.
Let's not overcomplicate it.
Hi.
You may not need grease for your crease, but you may want to look into a pair of glasses ;-)).
As the above replies indicate:
Yes: if you have an L.S. diff (whether it's part of the gear oil or a separate additive),
No: if you don't have an L.S. diff
Buy a good synthetic brand ( Mobil1 , Amsoil, Royal Purple, Redline, etc).
Good luck!
Cheers
Good luck!
Cheers
