lifting a 4x2
lifting a 4x2
I Have A 99 Fi50 4x2 Running 275/70 R16's On A 16x8 Inch Wheel, But I Want To Run 285/75 R16's On It Instead. I Know I Don't Have To Lift The Body To Make Them Fit, But I Think It Would Look Better If I Did. My Questions Is This: What Is The Average Cost Of A Professionally Installed 3 Inch Body Lift?
Also It Has A 5 Speed Manual Transmission. With The Larger Tires Should I Get The Tranny Re-geared (i Do Not Plan To Tow) And Have The Speedometer Readjusted? Also What Is The Aproximate Costs Of Doing These Two Things?
A Performance Accessories body lift kit should be right around $150. I've seen installation quotes from $100 to $800 so it varies greatly. Your best bet is to grab a buddy or two and install it yourself. Also, it's your rear end that needs to be regeared, not your transmission. I have no idea on the cost for that.
Alright, another 4x2 going up!! COOL!
I've got a 4x2 on 37" tires. Total lift is about 14". My RCD suspension lift cost me $1400 OTD installed (they gave me a deal), my 3" body lift cost me $500 installed. I had my rearend regeared to 4.56's and that cost $550. I have an automatic trans, which was still running too hot so I had to add a tranny cooler and bigger alum pan. I have a Superchip and I had that reburned to the new set up so my speedo is dead on. I'm doing a hair over 2K rpms at 70 mph. I get 13-16 mpg., and I have a V6. Lift away baby!!
https://www.f150online.com/galleries...297-126477.jpg
