Rear Suspension Help - Please
I am trying to finish my Roush installation on my 2002 Lightning and have run into a problem with the right rear leaf. I have the left installed ok. I can't get the right rear leaf to align properly. With the spring in place - the pin located in the axle - the front end of the spring won't align with the frame mount hole. When I first removed the old spring and put the new one in place it was off about 1/2 the hole. I have the axle on jack stands and a floor jack under the hitch. I tried lowering the floor jack some - that didn't help . Then i raised it - that didn't help. Then I lowered it - still no help. Each time I raise or lower it gets off further. I need some ideas - what should I do to get it aligned?
Thanks,
Bob
Bob
Thanks,
Bob
Bob
