Front spacers and rear block?
i have a 2001 screw. Yes im talking about a leveling kit in the front and a block in the rear. The reason im asking this question is that if i were to put a 2 1/2 inch leveling kit in the front i would be higher in the front than in the back. I have measured it. So i just wanted to put a blcok in the rear to level it out. So it would be like a 2 1/2 in front and 11/5 in the back. This will work?
what's this 2 1/2 inch leveling kit you're talking about? Your 01 F150 has torshion bars to adjust the front ride height. tighten up the torsion bar bolts to get some lift. If you don't mind the factory "rake", crank the torsion bars to raise the front about 2 inches, and then put 2 inch blocks in the rear.
The "leveling kits" are for new style 04+ F150's as far as I know.
