Noise While Turning Help
Noise grinding noise from steering
I too have a "04 F-150 ext and when warm turning left and right at a stop or moving theres a grinding noise(like pwst pump) and I can feel it in the column and steering wheel. 33,000k. When cold it's not there much, but as it warms up it starts to make noise. What I feel on the wheel is like grinding,humming feel. Taken to dealer 4 times and they said maybe a rack is tight or the power steering pump is bad. But a part needs to be shot before they can replace anything. I made them put a note on my service record about the noise so if it fails after warranty I WILL NOT PAY to have it fixed. Then I had them print it out for me to cya. I think it's the pump. Anyone have ideas I welcome ideas.
steering noise problem as well 04 f150 fx4
I am also experiencing the same steering noise in my 2004 F-150 Scab FX4 build date 08/2004. I hear a noise the same as you guys and can feel it in the steering wheel. Very prevalent when moving back and forth and the truck is parked. I took it in for an oil change on Friday and told the service dept. about it as well as my brake shudder when braking problem due to warped rotors. I am supposed to take it back in this coming week - they said they would have to take entire steering column apart and inside around steering wheel to diagnose and it could take 3-4 hrs so and all day thing. I think I found a TSB on this tonight or at least some information. TSB 05-15-01 http://www.alldata.com/tsb/Ford/1123...5-1/index.html
They also wanted to charge me $275 to turn the rotors and replace brake pads. I've got 27k on it and there is a TSB out for the rotors so as soon as I get this work done and know more I'll post it on here.
