Tires Rubbing
tires rubbing
Iron_lung I have the 04 f150 with the fabtech 6" lift as well as the nitto terra grapplers 325 60 r20 and I have the same problem. The tires rub on the back part of the fenders. You cant really cut anything there. What is your offset? Mine is a -25mm. I might buy a 3" body lift so I can get rid of the problem. Good luck!!!!!!!!!!!!
Originally Posted by wandell
Try drilling 2 holes through tthe inner fender and running a plastic zip tie through them and pull the plastic back some.
I just came back from doing this to my truck..... You are a life saver. I was dreading having to cut the back of the fenderwell. It works great!
