Changing power steering fluid
I have an '01 F150 and I would like to drain and replace fluid in power steering. All I have been doing in the past is suctioning out old fluid in reservoir with a turkey baster. Is it possible to disconnect the return line from pump to reservoir, insert it into a bottle, so the engine while running, can pump out old fluid, while I add clean fluid to the reservoir? Anyone know which line is the return line? Thanks,
